Discovery 5 trailer light plug
It is not available separately. I'd suggest buying a universal one and just replacing the connector part and still use your LR wiring harness.
This one looks like it will mount up: You won't need any of the wiring or brackets, jus the connector.
This one looks like it will mount up: Amazon.com: Hopkins 47185 Multi-Tow 4 Flat to 7 Blade and 4 Flat Adapter : Automotive
No, not plug and play. You will have to remove the wires from your 7-pin connector that has the broken cover and connect them to the new one. They should be just screw terminals holding the wires in place inside the 7-pin connector. Not bad.
No plug and play optin available.
