Easy entry / exit menu
Old Feb 9, 2022 | 10:29 PM
New2LRinCA's Avatar
Default Easy entry / exit menu
Has anyone else noticed that the driver seat easy entry/exit option is gone from the instrument panel menu? I used to have it, and the seat does it, but that menu item no longer exists.
Old Feb 9, 2022 | 10:42 PM
gcap's Avatar
Not sure why the manual says that, the only menu item that remotely looks like that on mine is the rear access one that slightly reclines the rears when the rear door is opened and raises the seat back if it's been previously folded.
For the function you're looking for, the on/off is controlled by rotating the round steering wheel adjustment **** left/right.
Old Feb 10, 2022 | 06:19 AM
Matthew424's Avatar
absolutely right! the **** is pretty small and on the ride side of the steering column. there is white lettering that says 'auto'.
Old Feb 10, 2022 | 12:32 PM
Disco V's Avatar
Why does this feature wait until you open the door before moving backward for the easy exit function?
At this point it too late, as I've already exited the vehicle.
My previous GX460 started the easy exit as soon as the ignition was turned off...far more useful.
Old Feb 10, 2022 | 01:10 PM
Matthew424's Avatar
I assume for the situation where you turn the vehicle off but not ready to exit (finishing a call on Bluetooth).
Interestingly the function does not re-engage (move seat forward and wheel down) until the ignition is turned on.
Old Feb 10, 2022 | 05:17 PM
Disco V's Avatar
As it should be...both ways should be driven by the ignition.
Old Feb 10, 2022 | 05:19 PM
bkjecu94's Avatar
I am my own knucklehead.
Bought my Disco back in March 2020 just as the shut downs were starting and was not able tp receive any tech instructions. I have learned by doing, reading in the manual/forums and watching YouTube videos.
I say all that because this is the first time in two years I finally know how to turn that function on. 🤦
I followed the instructions in the manual... they did not work so I figured i did not have that option and and gave up.
Thank you for the post!!!
Old Sep 15, 2022 | 04:39 AM
davisopr's Avatar
Maybe i am being a knucklehead, but when i try to push that button to Auto nothing happens.....
Old May 25, 2025 | 07:56 PM
magesh's Avatar
Just purchased a 2023 SE LWB & it has memory seats, etc ... However, I'm not sure if this has this easy/exit feature? The button on the right of the steering is set to Auto.
Somebody suggested I disable it, lock & unlock the car and put it to Auto. Tried. No love. Checking the build sheet, the Convenience Package is not there. Is that required?
Any other suggestions?
TIA
Magesh
mreloc
Jun 2, 2024 02:32 PM
DiscoBuckeye
Jun 12, 2016 08:29 AM
crashbump2
Mar 10, 2013 02:30 PM
LitleSuzie
Jan 18, 2008 01:58 PM
rover2003
Nov 7, 2007 09:53 AM
