Front and rear differentials and transer case DISCOVERY 5
Old Feb 12, 2026 | 04:12 PM
Jmudya's Avatar
Default Front and rear differentials and transer case DISCOVERY 5
Hi guys, my turn to change oil on my discovery 5 2019 hse
i have a 2-Speed Transfer Case and an Open Rear Non Locking Differential on my vehicle
so i want to buy
2 litrs of RAVENOL Gear Oil VSG 75W-90 GL-4 GL-5 1Land 2 litrs of
RAVENOL Transfer Case Fluid TF-0870 / DTF-1 1L +$35.9!
I absolutely can’t understand about fill/drain plugs
is it same both differentials?
Like 2 of these TYB500110G
https://www.roverparts.com/differentials/plugs-gaskets-seals/TYB500110G/
And 2 of these TYB500060G
https://www.roverparts.com/differentials/plugs-gaskets-seals/TYB500060G/
and what about transfer case, do i need to change fill and drain plugs too? I found i can change Fischer Plath 18X22X15CU cooper washers. I found this on amazon
https://a.co/d/0cqs3AWG this drain plug, is it same for fill?
could you help guys please, i just scary to leave my car at service and they will not have all parts to make that
thanks in advice all
Old Feb 12, 2026 | 06:56 PM
ponderosajack's Avatar
If you can just replace a washer the old plug should be fine. In my opinion only. When I did my front and rear differentials and transfer case I just reused my plugs (fill and drain) and didn’t even replace my washers. 20k miles ago and they are all perfectly dry. No seepage. No discoloration. No dampness. Again- that’s my experience with it.
Oh yeah. I have also done it the same way on my X drive BMW and my other rear wheel drive BMW.
Just always loosen the fill plug before the drain plug so you know you will be able to refill it.
Old Feb 13, 2026 | 10:50 AM
sowrco's Avatar
Three Land Rovers over 20 years and ditto. To be honest I replaced nothing.
Old Feb 13, 2026 | 02:24 PM
Jmudya's Avatar
Default I have got answer from officials
so i want to buy
https://www.roverparts.com/different...ls/TYB500110G/
https://www.roverparts.com/different...ls/TYB500060G/
Old Feb 17, 2026 | 11:03 PM
462disco's Avatar
Grab a magnetic drain plug for your transfer case. $25 and some change, I run this one - very well made & strong magnet.
Amazon Amazon
928paul
Sep 24, 2024 07:53 AM
jethron
Mar 5, 2024 10:50 AM
thebilgerat
Oct 18, 2021 01:42 PM
1979rover
Jul 20, 2021 08:09 PM
chad420
Jul 28, 2009 11:32 AM
