Headlight adjustment with LED lights
Old Nov 3, 2018 | 07:22 PM
ponderosajack's Avatar
Default Headlight adjustment with LED lights
Has anybody adjusted their headlights with LED headlights? I'd like to raise mine a little bit. The owner's manual shows how to remove a headlight but not how to adjust it and I haven't looked at it yet to see how to do it.
Old Nov 5, 2018 | 07:58 PM
OK, never mind. I found the adjustment. Uses a large Phillips head screwdriver through a hole each plastic cover, or remove each plastic cover with the two quick release fasteners, Then, turn each Phillips head screwdriver counter clockwise to raise the headlights.
Old Nov 6, 2018 | 07:28 AM
Groucho123's Avatar
I read in the owners manual that they are self adjusting. I wonder......
Old Nov 6, 2018 | 09:14 AM
I know I raised it. I counted the turn on the screw driver and saw a related component turn as a result. Marked it with a sharpie so I can put it back if I need to. And I watched the light pattern raise. I doubt the automatic function will counteract it but we’ll see.
Eurobahn LandRover
Detailing
Jan 18, 2016 04:00 PM
Scout_Beagle
Apr 5, 2015 08:06 PM
Robmcin
Apr 1, 2011 08:05 PM
Disco03
Dec 1, 2008 08:08 PM
hec
Oct 21, 2006 06:01 PM
