Has anyone ever sprayed intake valve cleaner thru the temp sensor port on the supercharger lid?
I have a bottle of the STP intake valve cleaner meant for GDI engines that's designed to be piggybacked into the intake tubing pre-throttle body, but I don't want the cleaner going thru the supercharger rotors/bearings. The only port that's post rotor is where the temp sensor is.. I was thinking on removing it, fashioning some sort of rubber plug and spraying thru that. Cleaner would be flowing thru the intercoolers to the intake valves.. Anyone done this before?
