Maintanance
Old Jun 2, 2021 | 11:38 AM
LR disco 5's Avatar
Default Maintanance
I was just wondering how often do I have to change the oil on TD6 engine because I've heard 8k but I don't know in km or miles??? also what other maintenance should be done and how often????
Old Jun 2, 2021 | 03:19 PM
Sasquatch86's Avatar
8k miles for oil and filter. 16k miles for fuel filter. I think the air filter, diff oils, transfer case oil and trans filter are 60k miles but I'm not definite. Wish maintenance was published in the owners manual.
Old Jun 2, 2021 | 04:54 PM
LR disco 5's Avatar
Do oyu know what oil do you use for the diesel engines? TD6
Old Jun 4, 2021 | 12:32 PM
Jhartz's Avatar
Maybe open the owners' manual . . .
Old Jun 7, 2021 | 04:09 AM
gmfain's Avatar
It's the Ford engine, So I use the Ford oil from Rock Auto.
MOTORCRAFT SAE 5W-30 F-150 Diesel Motor Oil https://www.rockauto.com/en/parts/mo...0QFA,oil,12138
6.5 quarts, 8,000 miles oil, 20,000 fuel intervals
other items I use from Rockauto
prices may vary
Rockauto
air MANN C35126 $20.79
CABIN AIR WIX 24511 $10.72
fuel MAHLE/CLEVITE KL1044 $36.79
OIL WIX WL7490 $13.55
MANN HU826X $5.02
WIPER LEFT TRICO 2417B $6.74
WIPER RIGHT TRICO 2017B $7.77
WIPER REAR TRICO 12I $4.01
VALEO 604486 Wiper Blade $ 6.36
VALEO 604483 Wiper Blade $ 6.37
Old Jun 7, 2021 | 05:17 PM
LR Max's Avatar
This is fantastic. Thank you.
Also glad you gave wiper information. I am a fan of new wipers often so good to see viable wiper replacements.
Old Jun 7, 2021 | 07:58 PM
BritCars's Avatar
You should check it meets the required Land Rover spec
With Diesel Particulate Filter (DPF): SAE 5W-30 meeting Jaguar Land Rover specification STJLR.03.5005.
Without DPF: SAE 5W-30 meeting Jaguar Land Rover specification STJLR.03.5003.
Old Jun 8, 2021 | 03:34 AM
gmfain's Avatar
The Ford spec is called out in the manual too. Of course it meets the LR spec and the Ford spec., its a Ford engine.
From Tech spec:
Specification SAE 5W-30 engine oil meeting Jaguar Land Rover specification STJLR.03.5005 or WSS-M2C934-B. If unavailable, 5W-30 engine oil to ACEA C2 specification may be used
File Type: pdf
Old Jun 8, 2021 | 03:37 AM
gmfain's Avatar
I use the Valeo wipers. Exact fit.
Valeo is a French global automotive supplier. Good products, mainly European market.
Old Jun 8, 2021 | 12:50 PM
LR Max's Avatar
On this note, does anyone have the differential (locking and open diff) and transfer case oil specs? Specifically for a 2019? I do have the rear differential locker. Wondering if the special fluids are the same from the LR3/LR4 days.
I had bad bearings on the rear diff of my LR3 and that sure as crap isn't happening to my D5. I'm keen to change fluid early.
