Oil Leak 2017 td6
Old Sep 26, 2023 | 10:42 AM
geekinc's Avatar
Default Oil Leak 2017 td6
I just hit 83k miles with no major issues, and a few days ago I noticed oil drips under the vehicle. I removed the belly pan, and there was quite a bit of oil, but after topping it off and another couple of days of observation, it's not big leak, but it's not tiny either. I lifted it up on jack stands and spent some time underneath, but I wasn't able to pinpoint where it was coming from. I was hoping someone here could point me in a direction as to common failures. I remember seeing something about the rear main seal but can't find the info. The leak seems to be on the passenger side, rear of the engine, with the belly pan removed. TIA
Old Sep 26, 2023 | 02:05 PM
RyanLR3's Avatar
I've had a bit on the passenger side as well but not much. Without a picture it's tough to tell exactly where you're referring. I suspect mine has some oil leaking down the back when I remove the oil filter during changes. I've never had to add oil between changes and just turned 100k miles
Old Oct 16, 2023 | 04:34 PM
geekinc's Avatar
UPDATE:
So after many days of investigation, I found that the oil was leaking from around the oil filter cap/oil cooler. I used a bore scope to dig around with the cap on and off, and couldn't find any glaring cracks. I felt the o-ring that was replaced at the last oil change(about 3 months ago) and remembered that at the time I installed it, it felt quite dry and old. I got the filter through NAPA(WIX) but it must have been old stock. So I ordered a new filter(K&N) and replaced the filter and after almost two weeks, I haven't see a drop of oil. After I replaced the o-ring and filter, I used parts cleaner to get a lot of the oil out then washed it with degreaser. I have used the bore scope several times to look for any oil in the little valleys on top of the oil cooler and it seems to have resolved. And thanks @RyanLR3 for the reassurance that it should not be leaking.
Old Nov 4, 2023 | 10:23 AM
Masbury's Avatar
Glad to hear that you found the source of your leak! I always clean and inspect the oil filter cap especially the groove for the O-ring. Then when installing the new one I put a thin layer for new oil all the way around the O-ring and reinstall and never had a leak so far. Just like when changing oil on my other cars with a traditional metal filter, I've always added that thin layer of oil to the rubber seal and never a leak.
reeshdar
Sep 21, 2021 07:22 PM
Old Bertha
Jul 12, 2020 02:23 PM
Pjpax
Sep 2, 2014 11:22 AM
thehun
Nov 19, 2010 10:22 AM
kfox77
Apr 25, 2009 01:29 PM
