Option pack question MY21 , Towing vs Adv. Off-Road??
I'm spec-ing a MY21, wanted towing as an option and notice there is a difference between the following
Towing Pack ($1150)
which says includes:
-All Terrain Progress Control (ATPC)
-Terrain Response 2
-Advanced Tow Assist
-Tow hitch receiver
And the
Advanced Off-road Capability Pack ($700):
-Terrain Response 2
-Configurable Terrain Response
for this option, we'd have to add the tow-hitch receiver for $650, which brings the total to $1350
So that makes the latter pack w/receiver added $200 more. Notice that what is missing from the "Towing Pack" is "Configurable Terrain Response."
Does this mean that "Advanced Tow Assist" and "Configurable Terrain Response" are mutually exclusive?? Or is there something else I'm not understanding?
Towing Pack ($1150)
-Terrain Response 2
-Tow hitch receiver
And the
-Terrain Response 2
I can't answer your question but in some serious off road adventures with my LR3, I never even needed to select any special terrain mode to have the traction I needed.
I certainly did use Low Range and Raised Suspension settings, but not Mud and Ruts or Snow, etc.
In fact, the one time I got stuck in some really slippery snow (I got out and couldn't stand up on it), off road, and off camber, I had it in Snow mode and couldn't get out.
Finally, I took it out of Snow Mode, and turned off Traction Control, and drove out successfully.
So unless you are planning some intense off road travels I doubt you'll ever need Configurable Terrain Rsponse.
Also, don't spec larger than 20 inch wheels if that's an option, because it's really hard to find any suitible off-road tires larger than 20 inch.
That's just my opinion.
When I went to the UK site to do a build, sure enough when I tried to switch from the Adv Terrain pack to Towing, it did say it would have to remove the Configurable Terrain Response at £220 (the US build tool doesn't itemize). Huh. I now wonder if the Adv Tow Assist on the '21 D5 might be a simulated component on Pivi Pro they had to make room for. Odd though that the Defender build seems to able to have both when doing builds.
Strange. I'll have to push my dealer to find out what's going on.
As I said, on an UK LR build, the Configurable TR is specifically removed when doing an option pack switch. so I assume it's the same for NA.
I have an email into JLR. We'll see.
FYI. Received a response for JLR this morning. They didn't get the question based on the reply as they said I could build with the Packs I mentioned.
Tried to make it more clear for them that one apparently cannot spec both Advanced Tow Assist and Configurable TR in the same vehicle. We'll see.
