P20ee
Old Mar 27, 2023 | 01:51 PM
sowrco's Avatar
Default P20ee
Attention hive mind: has anyone had any experience with the P20EE code on their Disco5 diesel? I did a look up and saw a number of things which could trigger a NOx out of spec alarm but was wondering if there was something common to this particular vehicle?
Many thanks!
Old Mar 28, 2023 | 02:41 PM
gmfain's Avatar
possible bad NOx sensor.
Old Mar 28, 2023 | 03:20 PM
sowrco's Avatar
Cheers! I'll keep you posted. I cleared the alarm in the hope that it was a spurious out of spec. So far, so good. I do have a warranty so if it pops up again it's going in.
Old Apr 10, 2023 | 12:59 PM
sowrco's Avatar
Update on this. Code cleared and never returned. However: yesterday, 300 miles from home a warning message popped up "no restarts after 250 miles, incorrect DEF quality". At that time I was 300 miles from home!
I drove the vehicle to my mechanic and left it there overnight - quite a stressful drive, making sure the auto stop/start was off and I didn't accidentally turn off the vehicle once I was in the red warning of zero miles left. One thing I did do - when I got the alarm I pulled over and removed the DEF injector from the exhaust pipe, and thoroughly cleaned it off, and the exhaust pipe hole. This did not clear the alarm.
Old Apr 11, 2023 | 10:38 AM
sowrco's Avatar
Update 2: I've been told DPF scrub and drain and refill of the DEF tank is necessary.
Old Apr 11, 2023 | 08:06 PM
gmfain's Avatar
do you have a local Land Rover mechanic to diagnose it? not dealer.
Old Apr 12, 2023 | 09:31 AM
sowrco's Avatar
Not really - I have one but it was risky dropping it off there at night in that area, so this time because of my warranty I dropped it at the dealer.
Old Apr 12, 2023 | 07:03 PM
David42six's Avatar
I've read that the "incorrect DEF Quality detected" warning can be triggered by a failed DEF pump.
Mountain Goat
Aug 30, 2022 11:08 AM
lrnoob
Dec 13, 2017 10:54 AM
KDOGG
Mar 24, 2014 03:59 PM
Robk12
Jan 30, 2014 09:27 AM
ebcolon64
Aug 23, 2011 09:22 PM
