Remote Start
My remote start ---stopped working.... 2020 Landover Disco HSE LUX.
App will beep flash lock unlock
go through the process of remote start screen lights up gauges sweep but then nothing. software all up to date..
then his weekend Battery DEAD came outside found vehicle with parking lights on and DOORS UNLOCKED !!!
Jumped the Truck to get it started.....took it to ORiley's did a load test checked ok just battery low charge.
took it home put it on a charger....all day to 100% next day drove the truck got home checked it again with battery charger showed 55% charge WTF.....
Any One any ideas btw had alternator checked also for out put alternator ok.
Yeah, [reported elsewhere] the stud thing started with multiple system failures, MMI goes berserk, sudden jerking motor operation, barely make it off the road, DEAD! Nothing. DOA! Call the tow truck. Happened 3 times. They had it 4 mths total. Remote start was another symptom. Started with battery replacement twice. Alternator. The ground wire. The terminal on the ground wire. The terminal on the ground wire to a different type plating. Added a star washer. FINALLY, just replaced the ground stud itself. No problems since.
UPDATE REPAIR DONE;
Picked up my Landrover Discovery 5
They performed the recall for the Ground Stud. I havent looked at it yet but it was done. They performed my 1st service oil change.
They said the needed to do updated on software for Body Control Module and Telematics Module.
I went over the truck. Locked the doors and hit the remote start form he app. It worked. Been driving it for a day or so and seems fine now.
I hardly drive his vehicle as I drive a Tesla 2014 Tesla Model S p85+. Anyway thanks to all who gave me input.
I hope my input can help others. Anyway if your vehicle is on recall list don't wait, that lack of ground on negative battery terminal will create a large resistance and kill your battery and other systems as well.
Tucker Woods (02-06-2021)
bentonrover
03-12-2010 07:36 AM
