Roof Rails
Old Jul 18, 2021 | 01:34 PM
dinkeldorf's Avatar
Thanks for sharing & good luck with the install. Can't wait to see pics.
Originally Posted by d5cvry
I got these and will be installing them next weekend once the rear ditch finishers arrive. Will be sure to take pics of the install. $192 after taxes
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old Aug 10, 2021 | 01:56 PM
mgazall's Avatar
4th Gear
Hey could you tell me what are ditch finishers and where do you get them. I would like to order those too from Amazon that you show, but do they come with everything or do you need something else that is not supplied ? Thank you -
Old Aug 10, 2021 | 02:20 PM
d5cvry's Avatar
6th Gear
@mgazall
Ditch Finishers are the plastic trim pieces that LR makes you replace when you go from no roof rails to roof rails. They are hard plastic pre-cut filler pieces for the "ditch" or "gap" in your roof line to fit the roof rails. They protect the nuts and bolts. Some people have used a dremel to cut out the notches needed for the roof rails. They are really hard to find online. I was lucky and found the front ones on ebay. Had to get the rear ones from my local dealer. $220 USD for all 4 pieces. Install directions along with part numbers are listed below.
  • Ditch Finishers - Front = VPLRR0157 ~ $120USD
  • Ditch Finishers - Rear = VPLRR0158 ~ $100USD
File Type: pdf
Old Aug 11, 2021 | 12:14 PM
mgazall's Avatar
4th Gear
Thank you very much for insight and taking time to answer -
leahmkeefe
Range Rover Velar
Mar 8, 2021 09:05 AM
Womble
Jul 30, 2015 01:58 AM
BillO
LR2
Apr 28, 2012 04:00 PM
Batesy
Jul 16, 2010 06:16 AM
dvs_dale
Feb 16, 2010 06:50 AM
