Sound system..
Old 11-26-2020, 09:13 PM
LoneStarLR's Avatar
I used to do the custom stereo thing 15-20 years ago. Strip out the interior, fit dynamat, couple of subs in the trunk components up front, all running off amps under Perspex floors etc.
But as car makers offered better systems, especially at the premium end I haven’t bothered as it’s not enough improvement these days vs the work involved, especially on highly integrated vehicles now.
I had a great Bowers Wilkins system In my Jaguar, and I would have ordered the upgraded B&W system in the XC90 had I gone that route, which sounds way better than the Meridian Surround system in the Disco, but it’s hardly a fair comparison as the Volvo system is a very expensive option whereas the Meridian is cheap.
But the Meridian Surround is good enough, although I highly recommend leaving it on the Meridian setting and making only small adjustments to bass and treble etc. depending what music you listen to it can sound very good, extremely clear, but if you’re into bass heavy hip hop or something like that then not so much.
TexasLandmark (12-08-2020)
Old 11-27-2020, 01:11 AM
gcap's Avatar
Does the buzzing happen all the time with all sources?
Maybe not your case but...
I had the HK upgraded system in an older 2000MY that constantly buzzed the door panels and I tracked it down to custom cd's or streamed music that were mp3 format that would often bunch up some lower frequencies and cause the issue. Playing the same tracks as .flac never caused the problem.
Old 11-27-2020, 11:47 AM
ponderosajack's Avatar
Only buzzes once in a while. Only source tested was XM radio or FM. Didn't try CD or other input. Funny, I know there's a CD player installed behind the flip open screen but I sure never use it.
Old 11-27-2020, 10:09 PM
canon_mutant's Avatar
There is?
I'll have to go look . . .
Old 11-28-2020, 05:24 PM
I had to look to make sure I was telling the truth.
Old 11-28-2020, 07:42 PM
I only have like 400 CDs.
utahbronco
Range Rover Velar
10-28-2018 01:11 PM
Fliprip420
01-25-2011 12:32 AM
Vazquezt
07-19-2008 12:44 AM
Mr. Krisztian
01-11-2008 10:18 PM
barmonkey
Sights N Sounds
08-10-2006 05:22 PM
Quick Reply: Sound system..
