Vehicle noise high speed D300 8/2021
Old Aug 13, 2021 | 01:57 AM
tsb's Avatar
tsb
Default Vehicle noise high speed D300 8/2021
Vehicle noise interior at higher speeds
New D300 is developing strange noises in the interior when travelling at around 180/190+ kph. The noise almost sounds like "interference" from the sound system, i.e. it's an electronic noise rather than mechanical. I only have the standard differential (the manual specifies that anything above 190 kph is not recommended if you have a rear diff). Perhaps it just doesn't like German motorways.
Anyone else?
Old Aug 13, 2021 | 09:48 AM
Matthew424's Avatar
Could it be the speed limiter? From a quick google search the top speed is 130mph (210 kmh).
Old Aug 14, 2021 | 01:49 AM
tsb's Avatar
tsb
Good point, I might have to check. It starts at about 185 km/h, which is a bit annoying.
By the way, LR responded too...just in case anyone else is having a "noise issue" (this could be an entirely different noise, of course) >> There is a service notice about strange motor noises in the program that our dealers and we are using with the code SSM75266 - AJ20-D4, AJ21-D4,
garywwood
LR4
Aug 12, 2020 08:32 AM
dasherman
Jun 1, 2018 08:05 PM
KernowDiscovery
May 30, 2014 10:44 PM
twaszak
Feb 5, 2013 12:15 AM
pickps
May 14, 2007 12:42 PM
