Who has the most miles?
Old Jun 27, 2024 | 02:31 PM
  #21
mtaylo32's Avatar
The trans fluid was changed at 95K by the previous owner at Land Rover, I purchased at 96K. Planning to do full fluid swap at 125K as I have an upcoming oil change due. Trying to hit the 1 million mile mark, let's go!!!!!
Old Mar 7, 2025 | 06:56 AM
  #22
mtaylo32's Avatar
130K on my TD6! Just bought some hot shots diesel treatment to give it a whirl, but still running like a dream on only routine maintenance.
Old Mar 7, 2025 | 08:06 AM
  #23
delly44's Avatar
now at 135,000 kms. still like the quiet comfort and utility of the vehicle. but again it has got diesel exhaust fumes in the cabin at start up (a $4k repair 15 months ago). LR dealer said i needed to replace the rear differential due to pinion seal leaking- down right fraudulent. had to insist they replace just the pinion seal- diff was not even low on fluid but they did zero investigation prior to recommending a replacement differential. recently went through the DEF quality warning- then DEF dosing warning when the DEF got low. topping up DEF then a half hour drive turns off the DEF warnings. Lesson learned- top up the DEF as soon as you get a refill warning. letting the count down run to “no start” will not end well. DEF system worked much better in my Touareg (even after the diesel-gate reprogram).
2019 TD6 discovery HSE
Old Jun 3, 2025 | 01:00 PM
  #24
mtaylo32's Avatar
Just hit 132,000 miles! Fresh oil change and DEF refill. Transmission serviced recently. Where are the updates?!
Old Jun 3, 2025 | 01:53 PM
  #25
gmfain's Avatar
I am at 113K miles.17 td6
Taking it in for Timing belt next week.
Old Jun 3, 2025 | 01:57 PM
  #26
mtaylo32's Avatar
Love it!
Old Jun 6, 2025 | 08:06 AM
  #27
adam5's Avatar
approaching 50k on my 2020 Td6.
lots of DIY services planned
Old Jun 12, 2025 | 01:48 PM
  #28
droolyFace's Avatar
116,000 on my TD6.
Since 108k I’ve gone the timing belt, changed fluid in both diffs, the t-case, transmission and cooling system. And oil changes at 5k intervals. All preventative. Only reactive as needing a new aux radiator.
It’s awesome.
Old Jun 13, 2025 | 09:16 AM
  #29
mtaylo32's Avatar
Great stuff!!
Old Jun 18, 2025 | 02:22 PM
  #30
Gnomadf's Avatar
Surely there are some with mega miles?
I might want to upgrade from my LR3, . I'm at 191K on the LR3 and would want to get that rom a D5!
