1989 rangie
I own a 1989 Rangie and have had it for 4 years. When I first bought it the suspension was raised 2 inches front and rear. It oversteared suddenly at speed on sweeping corners. I had it checked by a wheel aligner and he said it was because the castor was zero instead of 3 degrees. I lowered it with standard springs and the wheel alignment settings are now correct. It still has a vey slight wobble at speed. I have had it checked by two landrover/rangie specialists and they cant find anything worn or bent. Any one have this problem? Any suggestions?
I have a 1991 Classic that had the same issue when I first bought it-- as yours. They get "tail happy" and will develop dangerous oversteer in corners when the suspension bushings are shot. I replaced ALL the bushings on radius arms, trailing arms, panhard rod, sway bars, etc.
Handles much better now.
read my tech info section at www.eurotekapg.com for more tips
Regards,
Geoman
Regards,
Geoman
ultimatepimp
07-05-2006 09:56 AM
