Andrés from Argentina.
Old Jan 9, 2022 | 09:57 AM
Andres87's Avatar
5th Gear
Default Andrés from Argentina.
Hi everyone I'm trying to recover our old disco 1 95 tdi 300 from rust and some other issues.
Leaving some photos here.
Main problems:
  1. Steering goes lock to lock in 1 and half turn to the left and 2 and half turn to the right, with a reduced turn ratio to the left. I can see some steering fluid leak, maybe needs a seal job and refit.
  2. Rust on front floors, suspecting of bad windshield replacement and leaks.
  3. Passenger side Motor mount is broken need to repaired.
  4. Needs suspension work.
  5. Electric windows, i have done the soldering job on the windows ECU and now power is going to the back and front windows, back windows works fine, front windows aren't rolling and a clicking is heard in the glovebox compartment area
Old Jan 23, 2022 | 10:34 AM
The Deputy's Avatar
Welcome to the board.
Someone may have put the pitman arm on in the wrong location, not centered, and that's why you have different turning amounts.
Rust, really doesn't look that bad...seen much worse.
Good luck, with the repairs. Dl's are pretty cool and awesome off-road.
Lukesa
Nov 8, 2017 06:31 AM
Meg
Off Topic
Nov 25, 2016 11:40 AM
innzane
Off Topic
Mar 21, 2012 10:39 AM
andyblissett
Mar 9, 2007 08:44 PM
