Bringing a Disco1 back from the dead
Without searching I have happened upon a 1996 LR Discovery for sale and in need of some TLC and perhaps a little more than casual repair. It is a cloth seat Disco I with manual transmission. Not worth much on the Edmunds/KBB sites. Engine runs well and only has 104k miles on it.
I have restored old Volvo's so nothing I have seen appears difficult or requires special tools beyond my cabinet and the auto parts stores 'rental' tools.
Known remaining issues are the front shocks which are described as failed and brake pads and rotors. The right front brake rotor shows that the brake pad has worn to the point of encountering metal-to-metal contact indicating that the caliper has seized. Rear muffler is rusted out.
There is no documentation on coolant service but the documentation would indicate that nothing had been done in 10 years, 10k miles. At this point on a 20 year old truck I would replace all the coolant hoses, the water pump and thermostat with a good flush of the entire system.
The owner appears to have attempted to keep this vehicle in driveable condition through the support of a professional independent repair shop. The truck has 3 year old, 5k miles, top of the line Michelin tires , 3 month old battery, replaced with OEM parts the brake master cylinder and clutch master cylinder, steering damper and spark plugs. Power steering hoses and oil pan gaskets have been replaced to resolve leaks. Manual transmission that has had the transmission, transfer case and rear differential oil changed.
Truck is for a Grandson, senior in HS and hopefully through college.
Got questions over in the technical forum.
No idea how the COLOR script got added.
BUCKLEY
May 8, 2012 08:04 PM
