Range Rover P38 Torque converter
hello everyone I'm hoping someone can shed some light on my issue, I have a 1998 P38 4.6 with 109,000 on the clock, only when the engine is warm say after 30 minutes driving there is a rattle coming from the bell housing at idle only in park and neutral.
Thanks in advance Lewis
Welcome. I haven't had my Disco very long or done much to it yet. That said- Is there an access panel on the bell housing where you could look and see if there is/ are loose bolts to the flex plate? Or maybe flex to crank bolts? Sounds like a noise best looked at sooner than later though. Good luck.
