Discovery 2 hard brake pedal
Old Aug 12, 2017 | 12:51 PM
Jcooper's Avatar
Default Discovery 2 hard brake pedal
Hi. Just changed the fuel pressure regulator on my 01 TD5 disco. While driving after I had to stand on the brake pedal to stop. The brakes work fine at speed! I've checked the vacuum hose at idle; 18" pressure. So doesn't seem to be pump problem. No fluid leaks from master cylinder. I'm seriously stuck! Any help greatly appreciated.
Old Aug 13, 2017 | 05:38 PM
freedisco's Avatar
welcome. How does the pedal feel with truck stopped. That is, is it something that happens with motion?
Old Aug 17, 2017 | 03:26 AM
Jcooper's Avatar
Default The pedal seems very hard when engine
Hi, it seems to be very hard when the engine is off. The pedal does sink about 5-10mm when starting. The higher speed that I do, the better the brakes. I can't find any vacuum leaks. Could it be a faulty check valve on the vacuum hose? The servo/booster doesn't hold pressure overnight. Doing the fuel pressure regulator was awkward to say the least, it's got to be something I've knocked or moved while changing it. Thanks for the reply btw.
Old Aug 23, 2017 | 09:05 AM
freedisco's Avatar
Um. huh. If you changed the fuel pressure regulator, did that raise the engine idle? If the engine is running fast, that will make for a hard-to-stop situation.... Hope you already got it fixed!
iambhooper
Sep 1, 2019 08:48 AM
BritCars
LR4
Jan 29, 2014 08:18 PM
cloaked96
Oct 19, 2008 10:42 AM
fordink1
Sep 20, 2007 06:45 AM
reconram
May 26, 2007 09:50 PM
