Having man ? On upstream o2 sensors
Old Jun 15, 2014 | 09:55 AM
Nailnheadbanger's Avatar
4th Gear
Question Having man ? On upstream o2 sensors
Hi I know this might be a dumb question but how does the ecu read the results of the new 02 sensors installed there is no lead that goes to wiring harness.
And I am trying to get oxygen sensor monitor to come off my scanner i have three codes.
With a 99 you are allowed two inc monitors
If I get off just one more i will pass inspection,and I cannot renew registration until I get inspected .so my question is how does the computer know that you replaced the o2 sensors.
The computer is tellin me the up streams are bad i bought them but I see no wire at all going to a harness that ecu would get info from .
They just clip into each other both up streams in front
Someone please help asap.thank you jeffre
Old Jun 15, 2014 | 10:02 AM
dusty1's Avatar
Clip into each other.....no
Little tabs at back of block (can see the from to of engine) holds the harness
Old Jun 15, 2014 | 10:09 AM
4th Gear
I can see on my discovery that they plugged right into each other i just want to know hoe does the ecu know u changed out your upstream o2 sensors
Old Jun 15, 2014 | 10:33 AM
tuercas viejas's Avatar
Basically the ECU will get a new set of signal pulses which will most likely differ from the originals. Each sensor signalling is recorded as STFT--short term fuel trims.
These are then computed as LTFT's-Long term fuel trims which finally set the fueling.
Operating the vehicle & going through drive cycles the ECU will 'learn" the new signalling and compute the LTFT's.
Fuel trim can be a valuable diagnostic tool - Eastern Manufacturing
T/V
Old Jun 15, 2014 | 01:19 PM
4th Gear
I'll give it a shot thank you so you know definitely there are no wires in between buth up streams
That go to a ecu by harness or anything
They just hook up to each other
Old Jun 17, 2014 | 01:57 AM
4th Gear
Yes they just hook up to each other there is no wire or lead that looks like it hooks up to the ecu.if not how can a scanned readt monitor ok come up to pass an inspection .pla replynasaj
Old Jun 17, 2014 | 04:04 PM
acamato's Avatar
Post photos. They do not clip into each other. If you have andriod tabket or phone, get a bluetooth OBD II reader and the torque app. You will be able to see the real time values from the O2 sensors.
philwarner
Jun 27, 2015 03:21 PM
aftermath431
Nov 2, 2014 07:59 PM
mblmaine@gmail.com
May 12, 2012 02:38 PM
Discolife
Dec 3, 2011 09:49 AM
Garrett
Feb 15, 2011 06:45 PM
