How manufacturer make keys
Old Jul 22, 2012 | 08:32 PM
obd2tool's Avatar
Default How manufacturer make keys
An Original Key is Needed manufacturer make keys,For manufacturer make a key, you must first have an original key or Key Cutter design to copy. The original is inserted into the key copier for the key maker to duplicate.
"Feelers" Trace the Original
Key makers feature a component known as a "feeler." This feeler may be a highly sensitive metal or plastic rod that closely traces--or feels--the outline of Peugeot Transponder Key. The information obtained by the feeler is feed back into the machine for processing by the cutting mechanism.
A New Key is in use
Once the feeler has traced the original, the cutter is ready to reproduce the design of the key. As the cutting mechanism passes over the blank key, a series of cuts is made by a rotating cut face. The cutting head moves over the entire length of the blank key, producing an exact replica of the original physical or Mitsubishi Transponder Key; this copy can then be inserted into a lock or ignition switch and turned to activate the unique tumbler combination within.
Jared9220
Jun 8, 2014 11:49 PM
ShadowMerchantBC
Jun 23, 2011 08:41 PM
bavarian_range89
Oct 6, 2009 11:23 AM
peter400
ROAMING WITH FRIENDS
Jan 27, 2009 10:37 PM
LRXD
Sep 13, 2006 10:57 AM
