It's almost been a whole year...
Old 04-08-2018, 05:28 PM
CamelChad's Avatar
Default It's almost been a whole year...
Hey All,
Just wanted to drop in and introduce myself. I just recently aquired a 2004 Discovery 2. I've been a rover fan since I was a kid and saw the camel trophy on TV, and had the opportunity to pick up one that I liked. These forums have been amazing on helping me bring the truck up to par, so I thought I'd join and share some of the successes I've had.
Chad
Old 04-19-2018, 03:27 PM
The Deputy's Avatar
Received 1,167 Likes on 842 Posts
Welcome to the gang. Your picture isn't showing up. Looking forward to seeing your rig.
Brian.
Old 04-20-2018, 09:33 PM
CamelChad's Avatar
Here are a few photos. Couple weeks after we brought it home, and our first camping trip with the D2.
The first year of D2 ownership was pretty standard from what I've read. I've included the list for the curious.New headers and gaskets were done 1 month before purchase by PO.
Replaced broken passenger mirror.
Replaced oil pan gasket.
Replaced cracked A pillar trim
Replaced worn shift boot and brake boot
Replaced tail lights
Replaced SAI and used JUKE's K&N Filter upgrade
Replaced coolant lines & expansion tank
New master cylinder
New front brake calipers and new pads all around.
Installed new plate for the hydraulic step
Installed Ladder
Reseated and created new gaskets after headlight cleaning
MacGuyver'd a new sunroof shade clip from a shelving L bracket that I painted.
Installed new drip rail corners.
Installed bumper and taillight lamp guards.
Installed britpart dashpeel kit.
Found cupholder inserts as the truck didn't come with any.
Restored headlights
Sanded out pitting, and repainted wheel arches and wheels black.
Added 180 Thermostat
New ancillary pulley
New serpentine belt
Still to do:
Chase down A Pillar/Roof leak
New spark plugs, wires, and coils
Remove front bumper to fill and repaint plastic chip
Replace springs
Install Custom A bar.
Install Roof Rack
Fix Radio popping and figure out what to do with the busted CD changer under the passenger seat.
Add CB Radio
Install front lamp guards
Install rock sliders
Old 05-02-2018, 04:31 PM
tnkeith's Avatar
Hey, I've got that A-Pillar/Windshield leak too. Leaks only when driving in the rain, not just sitting in the rain. Would like to hear what others have done to fix it.
Old 05-02-2018, 04:41 PM
Sixpack577's Avatar
Aftermarket headers?
If so, do you have any pics or details?
Old 05-02-2018, 05:53 PM
CamelChad's Avatar
I'll take a photo and post it, but I believe they are from LR...pulled from the local pull-a-part judging by the rust on them.
Old 05-02-2018, 05:55 PM
CamelChad's Avatar
I've got the exact same problem. Planning to pull the headliner in a few weeks and spray it with bedliner. Planned on addressing it then, but I'll make sure to take plenty of photos and do a write-up. I've also got a TSB somewhere documenting a similiar problem. The solution was supposed to be a crack in the right front drip molding. I found a new one at the salvage yard so I'll go over that too if some epoxy doesnt do the trick. I'll also be taking an amateurish look at the sunroof and see if there are any issues there.
Old 05-02-2018, 06:38 PM
Sixpack577's Avatar
Thanks, but they are not headers then, they are the stock exhaust manifolds
Old 05-02-2018, 06:39 PM
Sixpack577's Avatar
Good time to put a radiant barrier above the headliner.
CamelChad (05-02-2018)
Old 05-02-2018, 07:32 PM
Dave03S's Avatar
I recently had that leak, fixed it by putting some clear silicon in the gap where the rubber strip at the top corner of the windshield is a tiny bit short... Since I recently had a new windshield installed my first guess was something related to that work. Has not leaked since.
Quick Reply: It's almost been a whole year...
