New Landrover Discovery owner
Welcome. You'll find the owner manual and shop manual set called the RAVE in the free download below. Word to the wise - the temperature gauge is not like your old car, inching up a little as it starts to get hot. Anything above 50% reading is suspect. A scanner or Ultra Gauge can show you temperatures exactly. These things can overheat from little problems like any other vehicle. But the gauge hides it from you until... whamo. And that is for the D1 or the D2. Now on the D2 another fun fact is that the front drive shaft did not come from the factory with grease fittings on everything When it dries out, the shaft can split and poke big hole in the transmission. Rebuild article in our tech area, or replace with a new fully greasable shaft. In our tech area is also a 60K miles service list, may as well get started on it.
maxspeedingrods
04-21-2011 11:11 PM
ffrllc
03-14-2007 01:08 PM
