New member. Needs help in getting in to the L322 Vogue 2004
Hello,
I am in a bit of a situation
The battery is fully dead in the Range Rover Vogue 3.6 diesel 2004 model.
Tried to open the driver side door with the key and it wouldn't open.
Can't take the front wheel off as the jack and the wheel lock nut is in the boot.
Tried connecting another battery to the side indicator and see if the locks would work. But the wires on the indicator started to melt. Not sure what i did wrong there.
Took the wheel guard/cover under the driver side wheel arch. Only managed to get it down halfway. Reached the 3 cables tucked in together. One is yellow, and 2 are black. One of the black one is like a bicycle brake cable. Pulled it a bit and nothing happened. Thought that would pop the bonnet up. Not sure if i should pull it really hard......
Any advice is much appreciated 🙌🏼
Pull the black cable harder?
Jared H
05-03-2018 08:13 PM
landi
11-30-2016 05:31 AM
