New Memeber from Bama
Old Mar 18, 2014 | 08:12 PM
TRider81's Avatar
3rd Gear
Default New Memeber from Bama
New here from Alabama, just picked up an 02 Discover II and looking forward to learning more about it and conversing with everyone.
Almost forgot to put a pic up
Old Mar 19, 2014 | 10:23 AM
drowssap's Avatar
welcome
Old Mar 19, 2014 | 10:46 AM
Shade Tree's Avatar
Welcome! What part of Alabama?
Hopefully some others will chime in and give you your homework assignment.
It will consist of downloading the "Rave" checking drive shafts, plugging coolant leaks, unplugging radiators, swapping thermostats and generally making sure you don't get bored on weekends for a while. Lots of fun and a learning experience for sure. You came to the right place, if you need any help, just ask.
"Drive Your Rover and Have Fun"
Old Mar 21, 2014 | 09:07 AM
TRider81's Avatar
3rd Gear
Thanks for the welcomes, this thing is definitely going to keep me busy. I've already started on it, changed the diff fluids, fixed a broken wire on an 02 sensor, this weekend will consist of plugs, wires, oil change and maybe a trans service. Really thinking about adding a seat switch activation kit. Got to track down whats making the whining noise under acceleration, any ideas?
Old Mar 21, 2014 | 09:15 AM
drowssap's Avatar
"Really thinking about adding a seat switch activation kit." just go to a bone yard and grab the switches and faceplate.
Use a very good ignition wires 8mm or bettter the heat under the hood eats them up, and they are a pain to change.
Old Mar 22, 2014 | 06:31 PM
Shade Tree's Avatar
If the whine is not better or gone after the fluid change, start a thread in the DII section.
Old Mar 22, 2014 | 09:06 PM
TRider81's Avatar
3rd Gear
Didn't make it to the fluid change, got the upper intake and dropped one of the alignment sleeves down the intake tube, so i spent the afternoon trying to get the intake off. So my first adventure is turning more than I bargained for. Good thing I work in a parts store. Also Shade I'm about an hour or so from ya in the Oxford area.
Old Mar 28, 2014 | 09:02 PM
jalodge's Avatar
Keep me posted if the fluid change fixes the whine.
LGarcia
Sep 16, 2012 02:34 PM
bigkev425
Aug 15, 2008 03:49 PM
ceven18
Jan 31, 2008 09:30 PM
desh72
May 5, 2007 12:03 AM
expeditionbrazil
Jan 23, 2006 01:45 AM
