Omaha, NE member 03 discovery se
Old Jul 8, 2009 | 11:56 AM
powerline's Avatar
3rd Gear
Default Omaha, NE member 03 discovery se
i just bought my first land rover. 2003 discovery SE7 charcoal on black. i have added hid kits 12k to the fogs and headlight ( no high beam) also i installed some 22X10 +50 with a 285-35-22 tire ( summer wheels ) i do still have the 18 inch factory wheels with nitto all terrains for the winter months.
Old Sep 13, 2009 | 03:16 AM
bus's Avatar
bus
Dude, your rig is so sick... What wheels are those exactly? You couldn't have pick a rim that fit better on your Disco.
I am actually looking to buy a 2003 Discovery within the week. I hope that mine can look as fresh as yours does.
Old Sep 13, 2009 | 08:14 PM
hilltoppersx's Avatar
make sure the 03 disco you buy is out of vin range for the 03's with oil pump problems
Old Sep 14, 2009 | 07:46 AM
powerline's Avatar
3rd Gear
which vin# are they??
Old Sep 14, 2009 | 01:10 PM
bus's Avatar
bus
3A771801 – 3A808362
Situation
Oil pump failures on 2003 Discovery Series II vehicles may be the result of a
manufacturing error. Locating dowel pins may be slightly misaligned permitting
assembly of the oil pump to the engine block, but placing stress on the pump housing
which can ultimately lead to leakage or failure.
Resolution
Whenever an oil pump failure is encountered on vehicles within the above VIN range
the only effective repair currently available is replacement of the complete engine
assembly including the front cover/oil pump manufactured to the latest tolerances.
Use the following components to affect a repair:
• LBB112301 4.6 Engine assembly LEV
• LBB111461 4.6 Engine assembly NON-LEV
Old Sep 14, 2009 | 01:16 PM
powerline's Avatar
3rd Gear
Originally Posted by bus
3A771801 – 3A808362
Situation
Resolution
close one.. A816
Old Sep 15, 2009 | 07:12 PM
flip3076's Avatar
8th Gear
Thumbs up
That is one sick ride! Where do you find the wheel set?
Old Mar 11, 2010 | 10:36 AM
hillbilly hangover's Avatar
Did you have any problem with those wheels fitting?
Old Mar 11, 2010 | 03:09 PM
salve7's Avatar
Looks good (and I don't usually say that with wheels over 18")!
Old Mar 11, 2010 | 03:39 PM
are you becoming a fascist? if you dare put 20's on your series i'm going to Repo it in the middle of the night.
