rear windows work only if wiggle wires
Old Apr 30, 2006 | 03:16 PM
rickranger's Avatar
Default rear windows work only if wiggle wires
Hi 94 rr lwb the rear window will work sometimes if i take the center glove box out and wiggle the wires going into the electrical box in the center console. any easy solution . has anyone else had this problem and been able to solve it thanks in advance
Old May 1, 2006 | 11:19 PM
Bait's Avatar
Default RE: rear windows work only if wiggle wires
That box is the window lift ECU. Remove it and take it apart. You will see a cracked solder joint on the circuit board. Solder it back up and wallah!
Old May 5, 2006 | 10:12 AM
rickranger's Avatar
thank you I will try that rick
coors
Oct 28, 2014 10:11 AM
porschebreath
Feb 21, 2008 01:00 PM
bhorwhat
Oct 16, 2007 10:14 AM
rickranger
Apr 30, 2006 03:24 PM
Rovercountry
Mar 22, 2006 03:38 PM
