Nitrous, Super Chargers, & Turbos All charged talk about going FAST.
Discovery 3 No limits!
Old Mar 30, 2014 | 07:18 AM
OffroadFrance's Avatar
Serious performance = serious money and work. If you want serious performance start with the bottom end first - billet balanced crank, steel rods, matched pistons, bolts etc. If you you go cheapskate and just try to increase horsepower top end you will soon end up with a heap of bent, mangled metal when a rod breaks and goes through the crank casing. Best talk to or better still let a pro engine builder/tuner prepare the engine it's cheaper in the long run. Then comes the other problems with all that HP, transmission and driveshafts, brakes and stopping power, etc, etc - it all ends up BIG $$$$$$$$$$$$$$
Old May 30, 2014 | 03:16 AM
Dane!'s Avatar
If I had an LR3 the only thing I'd want to do is add solid axles under it.
OffroadFrance
Off Topic
Apr 8, 2015 04:12 PM
tbesselman
Feb 13, 2012 07:01 AM
STi NUt
Engine & Internal
Sep 8, 2007 01:22 AM
DNTL911
Nov 29, 2005 11:19 PM
RobFrey1
Oct 14, 2005 12:14 PM
