rebuilding turbo on 2015 RR evoque 4 cyl
My 2015 RR evoque has its original Turbocharger. Everything works just fine, as it should, but eventually when the Turbocharger dies, I would like to rebuild it. IF you are experienced along this line, may I ask a few things: 1. I imagine rover turbo in evoque has quality ball bearing on its shaft, can they be pressed out; new bearings pressed in? Other than seals, etc., what else needs to be changed in restoration of unit? Overall, your thoughts on restoration of Rover Turbo? Thank you.
