Arc Welding
Old Aug 22, 2014 | 04:16 PM
OffroadFrance's Avatar
Default Arc Welding
I did some arc welding today, what we often here call 'stick welding'. Well I haven't used an arc welder for some years and thought I'd just pick up where I'd left off all those years ago ............. right. Well, as I discovered, it ain't that simple and when the rod wasn't stickig to the workpiece the results resembled a bunch of small grapes. Time for a steadier hand and a rethink. I was using 2.5mm fluxed rods and 95amps, soooo, up the amps to make things easier, fortunately I was welding 1/8" plate to the same thickness 40mm SHS. I ended up using 110amps with a lot of weld spatter going everywhere but managed to run half reasonable welds. Half way through the wife had made me a pastrami rye sandwich and some tea, so I stopped. She then said what did I expect as I hadn't arc welded for a long time and totally out of practice ................. hmmm, ever felt the urge to commit murder ................
Old Aug 22, 2014 | 04:23 PM
dusty1's Avatar
nice, at least she fed and watered you. "slow and steady" sometimes easier said than done.
btw, we call it stick welding too.
Old Aug 23, 2014 | 03:39 PM
Gave the welding another 'bash' today as they wanted $96 for a new MTD Lawnflite 30" rideon cutter blade to replace mine which I'd sharpened to death. Sooo, I bought two hardened steel flail mower cutters for $4 and welded one on each end of the mower blade thereby saving myself a 'truckload' of cash. I over did the arc welding for security and peace of mind as I wouldn't want them flying off cutting through my ankles or anyone elses come to that.
SurfRat
Jan 16, 2012 10:17 PM
devildog01
Mar 2, 2010 06:33 AM
03discoman
Jan 22, 2010 11:03 PM
NiteTrain
Off Topic
Aug 20, 2009 05:48 PM
jgbufton
Nov 17, 2007 10:04 AM
