Roof Rack - Seeking Guidance
Old Jun 29, 2015 | 08:23 AM
raburrell's Avatar
4wd High
Default Roof Rack - Seeking Guidance
2003 D2. I've had the expedition rack, mounted to gutters.
What was Great
  • Solid mounting
  • Lights mounts
  • Looks like you mean it
Problems:
  • Wind howls at 30 mph
  • Too Tall when unloaded
  • Gaps between bars let stuff fall through
  • Hard to clean car roof
  • Rust was starting to bubble up under paint
Can anyone suggest a Roof Rack that:
  • Low profile (I don't think I really need a rail above the rack since I tie my stuff down, it's not going to roll off)
  • Mounts to gutters
  • Covers 1/2 the roof length
And should it be aluminum or steel? Should it have a wind deflector? What's the best way to keep the jack up there?
Thanks in advance.
Old Jun 29, 2015 | 08:45 AM
dusty1's Avatar
Front runner has half rack without sides
Old Jun 29, 2015 | 04:08 PM
TOM R's Avatar
what about the hannible racks? they are aluminum iirc, aluminum = expensive
Old Jun 30, 2015 | 07:15 AM
raburrell's Avatar
4wd High
Default Thank you for the follow up
I appreciate the suggestions. I'll follow up on both.
Thanks.
Old Jun 30, 2015 | 09:58 AM
antichrist's Avatar
Won't help with the sides (but I like the additional safety of them in the event a tie down fails) but if you install the farmtek flooring that will stop things falling between the bars.
You can fabricate an air deflector to help with the noise.
Any roof rack is going to make it harder to clean the roof.
For the hi-lift you can buy ready made mounts or make your own from pipe hangers, threaded rod, stop nuts, fender washers and wing nuts.
Old Jul 2, 2015 | 02:33 PM
acg's Avatar
acg
ARB make a very nice half rack.
stimpy774
Nov 4, 2013 07:45 PM
Nthusiast
Apr 15, 2009 09:45 PM
bigugly82
Jul 2, 2007 03:38 PM
dinandan
Jul 4, 2006 10:43 AM
dinandan
Jun 22, 2006 07:22 PM
