Welding advice
I want to learn how to weld. I did it in high school for about a year but that was almost 10 years ago. My plan is just to buy a book on amazon and look for a used welder on Craigslist. Between practice and youtube videos I figure I can pick it up after a while.
I don't know much about welders and I certainly don't know how to spot a good deal; does anyone here have any purchase advice for me?
I'd look for something like this on CL or buy it outright -https://www.northerntool.com/shop/to...SABEgJk4PD_BwE You won't have to worry about gas with flux core wire but you will get far more splatter with it. Generally a low amp/thin sheet steel welder is pretty good for general light welding. TIG is more expensive in any config and you'll need the shielding gas to go along with and like Offload mentioned TIG welders are dual personality - Stick. They generally pull more amps, 30A at your wall outlet so most don't have a 30A circuit handy..... Stick is not dead, it's still used on all heavy gauge steel work. Anything carbon over 1/4" I'm still using stick on. Stainless is TIG and if your good at not running too fast with MIG it can tackle pretty heavy gauge as well. I use all three to this day for work and play.
I ended up being lazy and moving. Now I have a 220 outlet and haven't restarted the search.
The hobart 140 was going to be my choice though.
Though the new vulcan line by Harbor Freight is looking very promising
Maybe once I get used to something basic, I can get a TIG/Stick setup and see how I do with that.
NEW TOOLS! I have an electric one but it's garbage. I just got a new air compressor from a (now defunct) Sears Auto though. I love having an excuse to add to my inventory of toys
Splatter is caused by the flux basically exploding but while doing that it does an excellent job of making the shielding gas. It's like boiling water, bubbles but makes steam. Requires more post cleaning than with gas, gas is strike, flow and go, done. I use a TIG lunchbox at home on a 110V 30A circuit in my pole barn. It's a dedicated circuit. I can fine tune my heat with it far better than is possible with a MIG. Thinner tungsten used on really thin gauge. Very precise.
