2000 Range Rover 2 lights staying on
Old 02-03-2018, 12:25 AM
Scarf's Avatar
Default 2000 Range Rover 2 lights staying on
Hello. I am helping my friend out with this 2000 Range Rover.
His front Driver's side (US) and back Driver's Side lights stay on. I can't quite remember which light on the front is one, I think it's a parking light. The back light is a running like, again I think. For the back one, though, I took out the lights to troubleshoot a bad blinker as well, and the light bulb that stays on is the middle one.
Now, he's using a hefty battery cutoff switch in order for his car to keep charge over nights. I've gone through every single fuse and relay, and removed them one by one. None of them make the lights go out EXCEPT for Maxi fuse 1, a 60 Amp fuse in the engine bay.
I'm wondering if there's a bad relay elsewhere, or a burnt out bulb causing issues, or even a switch acting up.
If the popular opinion is a switch acting out, I could use a quick refresher course on removing switches from the dashboard of a 2000 Range Rover.
blast20
04-23-2010 04:18 PM
luxury1
12-31-2008 07:57 PM
DetroitRover
09-12-2008 12:12 PM
nestep
08-15-2008 08:11 PM
Tilt2Play
06-29-2008 07:05 AM
Quick Reply: 2000 Range Rover 2 lights staying on
