Range Rover Classic (1st Gen) Talk about the Land Rover Range Rover Classic within.
Disco Radio on the Classic
Old Feb 23, 2020 | 01:21 PM
ClassicPortugal's Avatar
5th Gear
Default Disco Radio on the Classic
Hi,
I’m trying to go as original as possible on my 95 soft dash SWB. As you all know, find some parts can be a challenging quest. My radio bezel is a mess, someone tried to “stick” a modern flip screen radio on it and broke a lot of it. So I already know, thanks to sickws6 that it’s possible to fit the Disco 2 bezel into the classic. So now my question is, did anyone installed a Disco radio on the classic already? Does anyone knows if it works?
Thank you all for the time and inputs.
Old Feb 23, 2020 | 09:49 PM
robertf's Avatar
They used the same radio from the factory. The cassette door may have said “range rover” instead of “land rover”, but that could be limited to 94s since every soft dash Ive seen said “land rover”. Radios are identical other than the silk screening. The difference is the amp
Old Feb 24, 2020 | 08:35 AM
5th Gear
Thank you Robertf. I’m gonna give it a try.
Old Feb 24, 2020 | 09:12 AM
5th Gear
The radio I’m looking at is the one in the pic. Seller on eBay say it has Bluetooth. Is this true?
Old Feb 24, 2020 | 07:11 PM
5th Gear
Does anyone knows if this radio has Bluetooth?
Old Feb 24, 2020 | 07:14 PM
5th Gear
Old Oct 8, 2020 | 01:04 AM
Idioteque2's Avatar
No it doesn’t have Bluetooth. And this is a D2 radio pictured. Only D1 radios will swap with RRCs. Make sure you get the original VIN number of the truck the radio came from, you’ll need that to get the code from the dealership.
ues defender
Oct 29, 2019 08:55 PM
elboy0712
Oct 22, 2017 09:33 PM
pwr198
Nov 6, 2010 05:58 PM
shark19
May 14, 2008 07:29 PM
pdolan
Aug 16, 2006 12:07 PM
