Range Rover Classic (1st Gen) Talk about the Land Rover Range Rover Classic within.
Electrical problem Range Rover Classic
Old Nov 11, 2021 | 11:54 AM
Richblack's Avatar
Default Electrical problem Range Rover Classic
Range Rover classic 1994. I have no horn, no hazard lights and no flash headlights (when lights are off). I replaced the switch (PRC5072) but still the same problem, so it isn't the switch. It strikes me that this might be easy enough to diagnose. All those elements should work with the ignition off, I think, so do they share a common earth or power supply, and if so, where is that situated in the loom - can I get at it without taking the dash apart? It's a PITA, because the horn is an NCT (Irish equivalent of MOT) fail straight off, so it has to be fixed.
Old Nov 11, 2021 | 12:04 PM
Richblack's Avatar
Just to note that I've found the Electrical Troubleshooting pdf and I'm going to take a look at that, but it's a bit over my head, tbh. Just to add that the other functions of that switch, indicators and full beam, do work.
Old Nov 24, 2021 | 10:28 PM
jt27wa's Avatar
7th Gear
relay
Old Feb 26, 2023 | 03:09 PM
lawsonmahoney's Avatar
I’m sorry to revive an old thread, but was a solution ever found to this? I’m having the exact same issue. I can’t find an accurate service manual for my ‘94 4.2, I’ve installed a new switch, I’ve check fuses, and checked the “flashers” relay. But still no horn, no flashers, no hazards. But indicators and brights work.
Old Feb 26, 2023 | 05:04 PM
Harvlr's Avatar
For the manual, WaltNYC on this forum has a link to the proper LR manuals for your RRC.
Brock88
Aug 17, 2017 12:51 PM
slowfiveo
Nov 8, 2015 07:29 AM
oilspotLR
Sights N Sounds
Jul 12, 2012 10:20 AM
outlander
Jul 6, 2005 01:26 PM
jabellas
Jun 24, 2005 03:26 PM
