Range Rover Classic (1st Gen) Talk about the Land Rover Range Rover Classic within.
Prospective Land Rover Series 3 Owner
Old Apr 3, 2023 | 04:58 AM
lachie's Avatar
3rd Gear
Default Prospective Land Rover Series 3 Owner
Hello,
I am looking at buying a Land Rover series 3 and have a few questions about a specific example I have just viewed and will potentially buy. It has been sitting for about 15 years and will not roll, seller believes that the drum brake shoes may be rusted which could be causing it? I assume that would be a fairly easy fix as new shoes are fairly cheap? Also it has a Holden 202 red engine, what is the effect of not having the original engine in a car like this? Is this a common swap to be made? I would assume that it would decrease the value of the car. It is a station wagon body type with Salisbury diffs and the safari roof, is this a rare specification? As I have struggled to find any for sale that were even in the station wagon body type, would it be possible to make an estimate as to what an example in working order like this would fetch on the market?
Kind regards.
Old Apr 3, 2023 | 05:03 PM
Harvlr's Avatar
Welcome to the forum. You should post your questions in the Series LR section of this forum. The safari roof and Salisbury axles are a plus. The replacement engine would be a minus in my opinion. If the problem is seized brakes you’re right it’s an easy cheap fix. But what if the diffs are seized?
Old Apr 3, 2023 | 11:59 PM
lachie's Avatar
3rd Gear
Thank you for your guidance, yes I will have to investigate as to whether it is definitely the brakes or if the diffs may be seized because that would not be something great to deal with. Thank you very much for pointing that out.
karlward96
Feb 21, 2022 01:01 PM
jcolyar
Other
Mar 1, 2018 10:45 AM
scol354412
Aug 13, 2014 10:16 AM
SeriesDude69
Other
Oct 27, 2009 10:59 AM
landroverman23
Nov 16, 2008 10:41 PM
