Range Rover Classic (1st Gen) Talk about the Land Rover Range Rover Classic within.
Range Rover classic, custom seat adjustments
Old Nov 2, 2020 | 08:43 PM
Nk94's Avatar
Default Range Rover classic, custom seat adjustments
Hi All,
I am looking to purchase a classic Range Rover. I found a fantastic example(94 LSE), no rust, engine is good, no bad oil leaks electronics all work etc. The big problem is that I am 6”4 and I don’t comfortably fit. I spent a bit of time fiddling with the seat adjustments but I was as far back as I could make it go and the steering wheel still was on my knees.
Does anyone know of any custom seating rails available? I’ve seen them for defenders but not range rovers. I’d rather do something someone has already done before or purchase a product. It wouldn’t need to go that much further back. I want to keep it original as possible but maybe that isn’t realistic!.
I’m in Australia but I can order parts from the UK.
Old Nov 16, 2020 | 10:47 AM
tnrangerover's Avatar
you could have a fab shop make you some new brackets to put it back another inch or two. bolt the brackets into the stock holes, then the seat into the new bracket holes pushed back a few inches. should be relatively cheap. it's easy to remove the seats. just 4 bolts.
mr4x4
May 8, 2018 09:23 PM
samjm
Mar 22, 2006 12:09 PM
rpatton
Aug 23, 2005 12:14 AM
outlander
Jul 6, 2005 01:26 PM
jabellas
Jun 24, 2005 03:26 PM
