Range Rover Classic (1st Gen) Talk about the Land Rover Range Rover Classic within.
range rover classic pulley question
Old Oct 9, 2025 | 10:15 PM
ez88's Avatar
3rd Gear
Default range rover classic pulley question
Hello,
I am a new forum member and I am looking to purchase a Range Rover Classic, the one in question the owner says has a broken pulley pin. I searched the forum but I couldn't find anything on it. I must be using the search feature incorrectly. How difficult is this repair on a Range Rover? I am pretty handy but I am not a mechanic. The last several non running cars I purchased over the years I have been able to get running and I would like to continue that streak. Any help would be appreciated. Thank you.
Old Oct 10, 2025 | 11:05 AM
Harvlr's Avatar
I’m assuming you are talking about the engine. You are in the right section of the forum for your question but you will likely get way more views in the Disco 1 section. The engine is the same.
Old Oct 10, 2025 | 11:10 AM
ez88's Avatar
3rd Gear
Yes, oh okay got it thanks.
I think the seller is talking about the woodruff key I will know more this weekend when I look at the vehicle.
Old Oct 10, 2025 | 03:39 PM
Harvlr's Avatar
If the Rangie is in good condition you will love it
Old Oct 10, 2025 | 04:24 PM
ez88's Avatar
3rd Gear
The body and interior look to be in great shape. The engine was running well and maintained before the issue with the woodruff key or pin. I will find out more this weekend hopefully it didn't do any damage to the engine. I am trying to determine if this is a job I can do myself. Thanks for the reply I am already loving it but we will see I have to be sensible. I don't mind be a little over my head if I purchase it.
Old Feb 22, 2026 | 07:28 PM
squibby's Avatar
5th Gear
If you are talking about the Pully on the end of the crank at the front of the engine that drives all of the belts, and also has a little bit of a small flywheel that has the marking on it to set the timing, well, I just removed the mine yesterday on my classic 3.5 V8. I removed and reinstalled it so i could change the pullies driving my aircon and power steering/alternator/pump etc.
I'm not sure that pully had a woodruff key in it. If there was a key, it didn't come out. The pully had a woowdruff style slot in it, but the ''male'' portion that goes in the slot was inside the bearing inside the block and had to align with the slot within the bearing, so it's wise to take note of where the timing markings are so that you have a rough idea of where to jiggle it to get it back on again. If the slot is damaged, I personally think that is a big deal imo because I can't see how you can stop the pully becoming loose over time by relying on the nut and spring washer that holds it.
I reckon it's a case of replacing the bearing in the block, sounds like a crappy job too me and if the pully can go one anyhow because it's damaged, you will not be able to trust your timing marks and setting the timing will have to be by guess work alone.
slowfiveo
Nov 8, 2015 07:29 AM
oilspotLR
Sights N Sounds
Jul 12, 2012 10:20 AM
spacey
Jul 30, 2008 07:01 AM
samjm
Mar 22, 2006 12:09 PM
outlander
Jul 6, 2005 01:26 PM
