Range Rover Evoque Talk about the Land Rover Range Rover Evoque within.
2016 evoque p0011 code
Old Jan 19, 2025 | 05:37 PM
donaldebert@hotmail.com's Avatar
3rd Gear
Default 2016 evoque p0011 code
My daughter’s 2016 evoque 3.has ck engine light. P0011 code intake timing advanced. No abnormal running or performance issues noted. She took it to a mechanic in the dallas area. The mechanic told her:
1. The intake camshaft timing is off.
2 it is not a vvt solenoid issue. They forced the position from their scanner and the solenoid responded
3. They want to replace timing chain (w guide and tensioner). Two sprockets (presumably both intake and exhaust phasers). And one vvt solenoid (presumably intake). $3200 parts 900 labor.
-looking for a “second opinion”.
my questions.
1. Could thin simply be due to vvt solenoid? Should i simply try this?
2. Can they easily point to chain issues with scanner and rule out solenoid? Or are they feeding her bs.
3. Should she be concerned aboul operation car and doing damage?
3 shop or ithere recommendations. Dallas area
thank you.
Old Jan 22, 2025 | 06:40 AM
gmfain's Avatar
I would clear the code.
Do a fresh oil change.
rescan for codes.
What are your oil change intervals been?
Old Jan 22, 2025 | 07:41 AM
3rd Gear
rescan for codes.
thanks. Oil changed at 10k mile intervals.
Old Jan 22, 2025 | 10:18 AM
gmfain's Avatar
I would recommend 5K oil and filter change. Cheap insurance.
My 2015 pure 2.0L ford engine, takes 5w-30 oil. I use Kirkland oil from Costco( same as Mobil 1). $3.50 per quart, oil filter from Rockauto $6
GavinC
Yesterday 06:49 PM
okdiscoguy
Jan 16, 2024 04:31 PM
