Range Rover Evoque Talk about the Land Rover Range Rover Evoque within.
Camshaft Position Sensor location
Old Aug 25, 2020 | 08:37 AM
vesuvio234's Avatar
Default Camshaft Position Sensor location
Hello,
New to Range Rover. AutoZone diagnosed my 2012 Evoque as having a bad Camshaft Position Sensor; where is it located on the engine? Where can I get a replacement at a good price?
Thank you in advance
Old Oct 5, 2020 | 07:19 PM
Jim Kinslow's Avatar
Originally Posted by vesuvio234
Hello,
The camshaft position sensor(s) are located on the top right side of the valve cover (opposite end from the VVT-S). There should be one over the intake cam (close to the vacuum pump) and one over the exhaust cam (close to the HP fuel pump). They should each be held in place by one 8mm or 10mm bolt. You should be able to get replacement camshaft position sensors at just about any auto parts store - especially for the 2012 - 2017 Range Rover Evoque since they typically use the Ford 2.0L engine (again, if I'm not mistaken). They tend to run anywhere from about $11.00 - $30.00 or more each depending where you get them and what name brand you get.
vesuvio234
Aug 24, 2020 07:57 PM
DeepBlueWater
Nov 22, 2019 07:51 PM
culture1
May 5, 2011 09:32 AM
icoolyou
May 23, 2007 08:52 AM
smi8387
Feb 7, 2006 01:15 PM
