Range Rover Evoque Talk about the Land Rover Range Rover Evoque within.
Range Rover Evoque 2.0 Diesel – Glow Plug Faults after Replacement + Cable/Connector
Old Sep 13, 2025 | 08:45 AM
Mustafa0398's Avatar
Default Range Rover Evoque 2.0 Diesel – Glow Plug Faults after Replacement + Cable/Connector
Hi everyone,
I have a Range Rover Evoque 2.0 Diesel (Ingenium engine) and I’m currently struggling with glow plug fault codes:
  • At first, I had errors on cylinder 1 and 3.
  • I decided to replace all glow plugs (cylinders 1, 2, 3 and 4).
  • While removing the connector from cylinder 4, it broke because it was very rusty.
  • In addition, the cable to the cylinder 4 connector was almost completely black inside.
  • I cut the cable back to about the fuel filter area (there it was nearly copper-colored, but still slightly brown) and renewed it with a new connector and cable.
  • Since then I have the following situation:
    • If the new connector on cylinder 4 is plugged in, I get Range/Performance fault codes on all four cylinders:
      • P06B9 (Cylinder 1 Glow Plug Circuit – Range/Performance)
      • P06BA (Cylinder 2 Glow Plug Circuit – Range/Performance)
      • P06BB (Cylinder 3 Glow Plug Circuit – Range/Performance)
      • P06BC (Cylinder 4 Glow Plug Circuit – Range/Performance)
    • If the connector on cylinder 4 is not plugged in, I only get:
      • P0673 (Cylinder 4 Glow Plug Circuit Open).
  • I have already replaced the glow plug control module.
My questions:
  • Do the glow plugs on the Ingenium engine need to be relearned/reset in the ECU after replacement (similar to injector coding)?
  • Or is the problem more likely related to the renewed cable/connector, possibly due to high resistance?
Has anyone experienced a similar issue and could give me some advice?
Thanks in advance!
rikkd
Feb 13, 2025 08:43 PM
Oleg-Lis
Jun 15, 2022 12:59 AM
Identamerican
Mar 18, 2022 01:00 PM
tommytwotone
Sep 22, 2009 05:09 PM
discobandith
Dec 10, 2008 10:45 AM
