Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
Error message workarounds / creative solutions (L322)
Old Jun 25, 2023 | 02:49 PM
Paul Hillman's Avatar
7th Gear
Default Error message workarounds / creative solutions (L322)
I own a 2008 RR and currently have 2 faults: TPMS (light and message), and Low Coolant Level (message only)
TPMS but probably need a new control module. Is it possible to use a scanner to turn the trouble light off? remove a fuse? open up the dash and pull/disable the yellow bulb that lights the trouble light?
LOW COOLANT LEVEL. After some research need to replace the overflow tank / resevoir as the sensor goes bad over time. I would rather not do this and would prefer to use a scanner tool to remove the message. Is this a possibility?
Old Jul 22, 2023 | 09:02 AM
sjz's Avatar
sjz
Don't do it. You don't need a scanner tool. A piece of wre is enough.
The sensor isn't an integral part of the reservoir and it can be twisted and pulled out. But before you do replace it, you can simply short the wires. When they are short, the level is good, open means too low.
MartinL322
Sep 13, 2023 06:36 AM
paige-lr2
LR2
Sep 6, 2023 12:14 AM
LR2driver
LR2
Jun 6, 2021 03:42 PM
Rufflyer
Aug 12, 2019 07:45 AM
