Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
l322 2006 4.4l camshaft sensors
Old Sep 25, 2024 | 12:51 PM
newworld's Avatar
Default l322 2006 4.4l camshaft sensors
2006 4,4l v8 l322
camshaft sensors replacement
hard job, mainly bc you cant see the sensors under all the wiring/hoses....the camshaft sensors are located behind the intake on either side of the inside of the heads in the rear of the engine. you are lying on top of engine to try to replace these.
8mm bolt holds it in, and the sensors are different from left to right. one sensor has a red locking tab, the other side doesnt.
even finding the sensor is a pain$#$@#$#.
remove engine cover
loosen all hose rail fittings on top of fuel lines, even then cant see sensor and now you have to somehow remove bolt and remove and replace sensor.
need long fingers, need a small box end 8mm wrench.
im not doing this one again
jimrawls
Jun 20, 2018 07:53 PM
dusty1
Feb 19, 2015 06:39 PM
chicane
Jul 8, 2014 09:57 AM
Chris-bob
Aug 11, 2011 01:17 AM
xb70valkarye
Feb 8, 2006 01:52 PM
