l322 knocking
Hi everyone , i have a 2004 l322 with knocking in the front end ,before everyone says its this and that i just want to note that i have just spent over $3000 on replacing every bush and moving part even put a new complete steering rack in and it still makes a knocking sound somewhere , on the hwy doesn't make a sound go slow on a rough road and its not to bad until you just touch the brake and it gets real bad, any thoughts would be much appreciated preferably from a mechanic.
Cheers Paul |
You check your brakes yet? |
Originally Posted by Reyesahr
(Post 670839)
My 04RR Has this issue as well im hereing more if i hit a bump. Dose this sound familiar? |
OP Is the set screw on the brake rotors present?
Reyesahr yours sounds more like control arm bushings |
It's probably the pads knocking on the calipers.
Here is my post on how I fixed it. https://landroverforums.com/forum/di...51/#post696472 |
