Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
l322 knocking
Old Nov 17, 2018 | 02:07 AM
roboz's Avatar
Default l322 knocking
Hi everyone , i have a 2004 l322 with knocking in the front end ,before everyone says its this and that i just want to note that i have just spent over $3000 on replacing every bush and moving part even put a new complete steering rack in and it still makes a knocking sound somewhere , on the hwy doesn't make a sound go slow on a rough road and its not to bad until you just touch the brake and it gets real bad, any thoughts would be much appreciated preferably from a mechanic.
Cheers
Paul
Old Nov 24, 2018 | 11:06 PM
Reyesahr's Avatar
You check your brakes yet?
Old Nov 25, 2018 | 12:11 AM
roboz's Avatar
Just pulled the calipers apart and greased them ,still does it.
Old Dec 21, 2018 | 11:04 PM
Reyesahr's Avatar
My 04RR Has this issue as well im hereing more if i hit a bump. Dose this sound familiar?
Old Dec 22, 2018 | 06:38 AM
OP Is the set screw on the brake rotors present?
Reyesahr yours sounds more like control arm bushings
Old Jul 13, 2019 | 06:12 PM
jjh221's Avatar
It's probably the pads knocking on the calipers.
Here is my post on how I fixed it.
https://landroverforums.com/forum/di...51/#post696472
Drake Anderson
May 13, 2019 08:31 PM
ljdiscovery
Jan 1, 2019 08:44 PM
ReconDoc83
Dec 20, 2018 10:20 AM
Davis31052
Dec 9, 2018 08:13 AM
GCBurke
Dec 8, 2018 09:59 PM
