Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
At my wits' end: Intake/Exhaust Valve Control Solenoids "Stuck Open"
Old Mar 15, 2023 | 08:52 PM
GrantRR's Avatar
5th Gear
Default At my wits' end: Intake/Exhaust Valve Control Solenoids "Stuck Open"
I have a 2012 Range Rover Autobiography Ultimate Edition.
Having had ten or so different Range Rovers over the years (from 95' Classic all through L405"s) I was really excited about my Ultimate Edition.
But I got a check engine light one day. Car still runs phenomenally despite the illuminated light. Idles fine, tons of power all through the rev range.
The ONLY performance hiccup I have ever noticed is when trying to slowly pull away from a gas pump, or slowly pull through a parking lot, the engine feels like it misses a step or gets tripped up for JUST a second, and then all is fine. And even that occurrence is super rare and only occasional.
I've cleared/driven and then re-read the following codes a couple of times now:
P0301-00: CYLINDER 1 MISFIRE DETECTED.
No sub type information.
P0303-00: CYLINDER 3 MISFIRE DETECTED.
P0305-00: CYLINDER 5 MISFIRE DETECTED.
P0307-00: CYLINDER 7 MISFIRE DETECTED.
P0300-00: RANDOM MISFIRE DETECTED.
P0316-00: MISFIRE DETECTED ON START-UP (FIRST 1000 REVOLUTIONS).
P0026-72: INTAKE VALVE CONTROL SOLENOID - CIRCUIT RANGE/PERFORMANCE (BANK 1).
Actuator is stuck open.
P0027-72: EXHAUST VALVE CONTROL SOLENOID - CIRCUIT RANGE/PERFORMANCE (BANK 1).
The P0026-72 and P0027-72 INTAKE/EXHAUST VALVE CONTROL SOLENOID - STUCK OPEN are the ones that inevitably come back within 50 or so miles of driving. The bank 1 of cylinder misfires and "under 1,000rpm" codes seems to follow at some point.
Here's what we've been through trying to sort them:
Brand new intake and exhaust camshaft solenoids.
Brand new intake and exhaust camshaft solenoid connectors.
New PCV valve (smoke test showed it was leaking).
BG Dynamic Engine Cleaner then Dynamic Rinse Oil (think BG EPR on steroids) and two or three full oil changes during that flush process.
Worked with AutoLogic OPUS IVS to update the PCM.
Took it to a shop with some Land Rover experience and they swapped the new solenoids and tested all the wiring to make sure those were all working correctly. Everything tested good. They were working IVS360 Support who finally left it at either getting a new ECM (which they didn't sound super convinced by) or replace the timing chain and tensioners, but again, they were giving that suggestion kinda with their shoulders shrugged.
I attached my camshaft correlation values which, correct me if I'm wrong, aren't super far off and wouldn't point towards a stretched chain or tensioner issue if I'm not mistake?
I absolutely adore this car, but my OCD can't have an engine light on the dashboard. Is there anything I am missing that I should be trying?
Endlessly appreciative of any help or suggestions.
Old Apr 23, 2024 | 10:00 PM
chitangi@gmail.com's Avatar
Was this ever resolved ..I seem to have the same problem. P0026, P0027, and random misfires changed the chains, tensioners, and rails. Any help will help thinking about getting solenoid connectors changed but still unsure ..any help would be greatly appreciated,
Old Apr 24, 2024 | 03:58 PM
GrantRR's Avatar
5th Gear
I emailed you directly. Let me know if you don't see it for any reason.
Old Jun 9, 2024 | 03:39 PM
dvelker's Avatar
Default Same issue
Hey GrantRR, my ‘11 is throwing exactly these same codes, and this was on start up AFTER I did a head gasket and all the chains/tensioners/gaskets, etc.
It seems to run perfect, but the codes remain.
What was your resolution?
Thanks!
Old Jun 10, 2024 | 08:27 PM
GrantRR's Avatar
5th Gear
Never did figure it out. A dealer in AZ that specializes ended up buying the car fully knowing of the issues. Not sure if they figured it out or not.
Old Apr 30, 2026 | 06:47 PM
TORRES5100's Avatar
did you ever figure it out same exact thing i did the cylinder head and timing chain getting the same code as well
Old Apr 30, 2026 | 06:51 PM
GrantRR's Avatar
5th Gear
Old May 1, 2026 | 06:59 AM
sjz's Avatar
sjz
Change the spark plugs.
Be sure you get a genuine set, as BMW engines are very fussy about their spark plugs. There’s only one NKG model that’s recommended. Don’t use any other replacement.
Farrancampbell
Range Rover L405 (Fourth Gen)
Dec 17, 2022 03:57 PM
ChicagoAv8tor
Apr 10, 2017 05:42 PM
Streambrewer
Oct 21, 2016 10:51 AM
jrmnw1
Mar 21, 2010 06:33 PM
mortythebison
Mar 13, 2007 10:29 AM
