Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
No crank no start after trans work HELP!
Old Mar 7, 2020 | 08:07 PM
John Monroe Zimmerman's Avatar
Default No crank no start after trans work HELP!
I had to pull the valve body and change the solenoids. Everything is back together. Car is close to level, but still short on fluid since I can't get it to do anything more than light up the dash. I did have U0101 lost tcm communication, and P0851 Park/Neutral switch input circuit low. So I pulled the valve body back out, realized the shift fork wasn't in correctly. Put everything back together. Plugged it back in, connection seems solid. Is it possible that I got trans fluid on the mechatronics plug, and that's enough to cause this? I HAVE NOT added fluid again in case I need to pull the pan back down again. I'm lost. This should have been such an easy job, but this has me stumped. Thanks!
Old Mar 17, 2020 | 12:42 AM
FlyingZebra34's Avatar
Any luck? The truck won't turn over if it doesn't think it's in park or neutral. The little things test our patience and tend to be the most challenging.
Old Apr 20, 2020 | 08:06 AM
Robert Summers's Avatar
6th Gear
Yes, please update. Did it work? Once you plugged everything back in did you get different codes? What's it doing now?
jj2
Jan 21, 2011 07:03 PM
ROVERTECH15
Mar 27, 2010 10:14 AM
lhgdale
Dec 28, 2008 08:38 PM
texmanmoore
Feb 23, 2008 09:18 PM
skyguy
Jan 17, 2008 09:29 AM
