Range Rover L322 (3rd Gen) Talk about the Land Rover Range Rover L322 within.
U210A Temperature Sensor Fault code
Old Feb 2, 2023 | 03:18 AM
Jimbo4864's Avatar
Default U210A Temperature Sensor Fault code
Hi,
My 2011 Range Rover Sport has developed a fault with the air suspension. On plugging it into my Icarsoft reader and interrogating the Ride Level Control Module, it has returned the fault code U210A Temperature Sensor. On clearing the code, it comes straight back. I don't think it's affecting how the vehicle drives, it still raises and lowers, however there is an amber warning triangle on the dash. Am I right in thinking this fault lays in the temperature sensor within the air compressor? Ive checked the vehicle doesn't drop on any corner to lose air overnight, so I don't think its a leak causing the compressor to work overtime. I've also read elsewhere that there is an error with later models, that returns this code and just needs t be plugged into an official LR Diagnostic to update the software, but I'm not sure that affects this year of vehicle. Any help would be greatly appreciated.
Old Aug 24, 2023 | 03:51 AM
ZGphoto69's Avatar
Did you ever find a solution? My LR3 is showing a similar fault... Suspension works great, but triggers fault every time I drive.
Old Aug 30, 2023 | 12:53 AM
sjz's Avatar
sjz
It's the air compressor temperature sensor that stops it from overheating.
Take the spare wheel out and look underneath the black turtle.
Jekyllman
Nov 1, 2022 10:36 PM
Amilcar Stuurman
Range Rover L405 (Fourth Gen)
Nov 24, 2021 01:21 AM
emkg
Nov 13, 2021 05:33 AM
Altitudes
Apr 15, 2019 08:38 AM
jrm123180
Feb 24, 2012 12:24 PM
