What now!?...
I need some help.. here's what happened-
2010 Range Rover HSE full size L322
My Husband put a new battery in my truck and the next day it was dead. So we put a new alternator in.. same thing, dead cell. Checked all fuses, they're good. Put a new MEGAFUSE on the battery and fixed that issue. However, now I cant get it out of park! LMFAO. When I use the little trick of pulling the lever under the center console it moves gears but when I drive it won't switch out of first. Also, now my cruise control, emergency park brake and a few other faults are showing up. Put a new brake switch in. Nothing changed. When we read the obdII code thingy all is good until the ECU tries to communicate with the transmission and it says gear shift position circuit sensor fault...
Also- I cant see any open wires or visible errors with the wiring.
Any help or suggestions would be appreciated
I cant really afford to take it to the dealership so we are DIY'in it..
