Range Rover L405 (Fourth Gen) Talk about the Land Rover Range Rover 405 within.
2013 Range Rover HSE L405 TPMS Fault
Old 10-30-2023, 10:12 AM
bombsaway's Avatar
Default 2013 Range Rover HSE L405 TPMS Fault
I have a TPMS System fault so I replaced all four sensors with LR066379 after market 315Mhz sensors but the fault has not cleared.
Does the control module need to be reset? Or is there another fix?
Any help would be greatly appreciated
Old 10-30-2023, 08:54 PM
Brandon Rosenblum's Avatar
Default Tpms
After market ones can be tricky. But if they are pre programmed resetting your TPMS should do the trick.
The procedure for this is to drive around for 15 minutes.
if this does not work they you got an issue with those sensors and they might need to be programmed.
OramaSEPR
11-08-2021 02:19 PM
knightmetro
LR4
07-02-2021 04:38 PM
Tonko007
05-06-2018 03:01 AM
Jlb
10-29-2016 08:19 PM
Jlb
10-29-2016 06:06 PM
Quick Reply: 2013 Range Rover HSE L405 TPMS Fault
